Combining two data series into one
miorinnovo
Postby miorinnovo » Tue Mar 10, 2015 11:03 am
I'd like to sue the growth rates of one data series that has ended and use those growth rates to extend another data series that replaced it bacx in time. Anyone know a quick and easy way to program that?
trubador
Did you use forum search?
Re: Combining two data series into one
Postby trubador » Tue Mar 10, 2015 11:10 am
Yes, you can quickly and easily do it with adjusting the sample period. You may also find @recode function very useful.
miorinnovo
Postby miorinnovo » Tue Mar 10, 2015 11:14 am
So I have the sample period covering both data sets. For example series 1 is from 1990 to 2000 and series 2 is form 2000 to now. How would I extend series 2 back to 1990 using those growth rates? It's easy in excel but I'm not sure how to do it in eviews. thanks
trubador
Postby trubador » Tue Mar 10, 2015 11:58 am
miorinnovo
Postby miorinnovo » Tue Mar 10, 2015 12:17 pm
Thanks. I think that link shows how to extend a series forward using the growth rates of a new series. Please tell me if I'm wrong.
I'm looking to extend a series backward with the growth rates of an old series.
trubador
Postby trubador » Tue Mar 10, 2015 12:42 pm
It is really quite straightforward to do that in reverse. Since you can do it in Excel, you already know how to formulate it.
miorinnovo
Postby miorinnovo » Tue Mar 10, 2015 2:15 pm
I understand the logic in reversing it to go backward, but when i tried only one data point was added to the sereis and the rest are still NAs :?
miorinnovo
Postby miorinnovo » Wed Mar 11, 2015 10:00 am
I am able to make a spliced series of the growth rates of one variable and then the growth rates of the second variable. Now I just need to know how to create a level series using the last data point and "growing" backward.
Postby EViews Gareth » Wed Mar 11, 2015 10:13 am
Might want to check my arithmetic, but the idea is sound:
'make some data create a 1990 2015 smpl 1990 2000 series x1=nrnd smpl 2000 2015 series x2=nrnd 'calculate growth rates smpl 1990 2000 series growth = (x1-x1(-1))/x1(-1) 'calculate x2 in the past smpl 1990 1999 genr(r) x2 = x2(1)/(growth(1)+1)
miorinnovo
Postby miorinnovo » Wed Mar 11, 2015 10:31 am
Hi Gareth,
That's essentially what I've been trying but it seems to only create one observation. It creates the observation reight before the start of the newer series and leaves everything else blank.
Postby EViews Gareth » Wed Mar 11, 2015 10:49 am
Which version of EViews?
miorinnovo
Postby miorinnovo » Wed Mar 11, 2015 1:46 pm
8
Postby EViews Gareth » Wed Mar 11, 2015 7:34 pm
Make sure it is fully up to date. Also make sure you copied my code exactly.
miorinnovo
Postby miorinnovo » Thu Mar 12, 2015 6:32 am
It worked! thank you again! (I had tried to create a new variable rather than extend the x2)
heyhey
Postby heyhey » Fri Nov 29, 2019 9:18 am
How would the code change in EViews 11?
