Comparing a forecast to the mean
miorinnovo
Postby miorinnovo » Fri Mar 06, 2015 4:17 pm
Can someone tell me how I can compare a forecasts RMSE to the unconditional mean?
Re: Comparing a forecast to the mean
Postby startz » Fri Mar 06, 2015 4:29 pm
Regress on just a constant?
Postby EViews Gareth » Fri Mar 06, 2015 4:36 pm
series ymean = @mean(y) scalar rmse = @rmse(yf, ymean)
miorinnovo
Postby miorinnovo » Fri Mar 06, 2015 5:09 pm
Great idea startz, thanks.
EViews Gareth, I tried your code and it says yf is not defined
Postby startz » Fri Mar 06, 2015 5:12 pm
Gareth meant
scalar rmse = @rmse(y, ymean)
miorinnovo
Postby miorinnovo » Fri Mar 06, 2015 5:18 pm
Amazing. Thank you both! :D
Postby EViews Gareth » Fri Mar 06, 2015 6:14 pm
No, I meant yf, where yf is your forecast of y.
miorinnovo
Postby miorinnovo » Fri Mar 06, 2015 6:18 pm
Oh, ok. So is it the RMSE of using the mean to forecast though? If so why do we need the forecast variable in there?
Postby startz » Fri Mar 06, 2015 6:20 pm
Do you want to find the rmse of your forecast compared to the mean, or do you want to compute the rmse of the mean compared to the original series?
miorinnovo
Postby miorinnovo » Fri Mar 06, 2015 6:29 pm
So I want to compare my forecasts RMSE compared to the RMSE that I would get if I just used the mean as my forecast.
Postby startz » Fri Mar 06, 2015 6:33 pm
Then y, not yf.
miorinnovo
Postby miorinnovo » Fri Mar 06, 2015 6:35 pm
Ok, and that code gives the RMSE of the mean as a forecaster, and
scalar rmse = @rmse(yf, y)
is to find the RMSE of the forecast?
Postby startz » Fri Mar 06, 2015 6:39 pm
yes
miorinnovo
Postby miorinnovo » Fri Mar 06, 2015 6:45 pm
Wonderful, thank you very much
