Importing Labels from xls/xlsx
osindi
Postby osindi » Thu Mar 05, 2015 4:52 am
Sorry if this has been answered already, haven't found any relevant details so far.
I'm trying to import data from an xls/xlsx file using eviews7.
I'm aware I can use the following command:
import "path/file.xls" range="Sheet!A4:X100"
However, I often get a date specification error. Does the sheet need to have some sort of standard format with the dates in column A? How would i define the sample / frequency from the code without having the dates in the xls file.
Secondly, I'm also interested in importing the names from excel as well. This seems easy to do if the names are directly above the data, but what if it's a couple rows above the data?
E.g. How would I get the names of the series if it was given in the following format:
Row 1: Name
Row 2:Unwanted details
Row 3:Unwanted details
Row 4:Unwanted details
Row 5: Data starts
Row 100: End of Data
Appreciate any help.
Thanks,
osindi
Re: Importing Labels from xls/xlsx
Postby EViews Gareth » Thu Mar 05, 2015 10:16 am
Can you provide an example file?
osindi
Postby osindi » Thu Mar 05, 2015 10:37 am
Hi Eviews Gareth,
Sure. So the names I would want are in row 3 of the excel file. And the data starts from row 7.
Thanks,
import_test.xls
(30 KiB) Downloaded 664 times
Postby EViews Gareth » Thu Mar 05, 2015 10:46 am
wfopen import_test.xls colhead=4 namepos=first
osindi
Postby osindi » Thu Mar 05, 2015 10:51 am
Thanks. Is there a way to do it using the import (or read function with xlsx)? or at least reading it directly to the current workfile?
Postby EViews Gareth » Thu Mar 05, 2015 11:10 am
Change wfopen to import.
osindi
Postby osindi » Thu Mar 05, 2015 11:17 am
great, thanks very much.
One last question though: Is it possible to import when the dates are not available? I guess you would need to specify what the dates are within the import function?
Thanks again!
Postby EViews Gareth » Thu Mar 05, 2015 11:32 am
Yes. The import documentation has details.
