Hypothesis Testing Wald
ssk322
Postby ssk322 » Mon Feb 02, 2015 4:58 am
Hi All,
I am currently having an issue to determine the responsiveness between two variables within my model in terms of Hypothesis Testing.
For example:
I wish to determine C(1) is more responsive than C(2). However I cannot simply input C(1)>C(2) within the Wald test.
Please advise.
Help is greatly appreciated.
Kind regards
Re: Hypothesis Testing Wald
Postby startz » Mon Feb 02, 2015 7:08 am
Input c(1)=c(2). Then look up the one-tailed critical value in a table.
ssk322
Postby ssk322 » Mon Feb 02, 2015 7:41 am
Thanks Startz for your swift reply. One more question regarding this. So if the result is statistically significant, can we determine that C(1) is not more responsive than c(2) given the equation?
Kind regards
Postby startz » Mon Feb 02, 2015 7:55 am
Well, you can test that one coefficient is larger than the other. I assume that's what you want.
ssk322
Postby ssk322 » Mon Feb 02, 2015 8:15 am
That is exactly what I am after. So does the equation c(1)=c(2) still apply?
Postby startz » Mon Feb 02, 2015 8:38 am
Yes. Of course you have to interpret the result. If the estimated c(1) is greater than the estimated c(2) and the t-statistic from c(1)=c(2) is greater in absolute value than the one-tailed critical value, then you can conclude variable one has a bigger coefficient than variable 2.
ssk322
Postby ssk322 » Mon Feb 02, 2015 9:17 am
Will this also apply to Chi-Square values? My apologies, I promise that is the last question.
Kind regards
Postby startz » Mon Feb 02, 2015 9:20 am
I don't think so, because I don't think you can get one-tailed chi-squared critical values.
ssk322
Postby ssk322 » Mon Feb 02, 2015 11:03 am
I think you're right. As my model is a SUR I will have to interpret the result if there is significance then H0: C(1) is more responsive than c(2) will ultimately lead to a rejection of the null.
Appreciate the help Startz!
