I'm trying to open an excel file in eViews from a VBA code in the spread-sheet. In the eViews program I am using the following:
wfopen "\\xxx\shared\xxx\xxx\zzz & zzzz\Lead Indicator\Trial DE Lead Ind.xlsm" range=eViews-data
However, when I try to run it from VBA with what I think the syntax should be like, it gives me either Syntax error or Expected:end of statement, depending on whether I use Range = "EViews-Data" (without quotas) or with quotas like below.
app.Run "wfopen ""\\xxx\shared\xxx\xxx\zzz & zzzz\Lead Indicator\UK Lead Test and 2014 Parameters.xlsm"" Range = "EViews-Data""
Could you please help me to find the right syntax for it? I haven't been able to find the solution in the forum.
Thanks a lot,
Marta
Opening an Excel file from Excel VBA (with wfopen)
Re: Opening an Excel file from Excel VBA (with wfopen)
Altaus:
You need to double-up the quotes inside the string. This includes the quotes around the range argument:
range=""EViews-Data""Who is online
