Urgent question about Cholesky Ordering
thomas-2424
Postby thomas-2424 » Sun Jul 19, 2009 1:59 pm
I was wondering whether you could answer a quick question on Cholesky ordering. I am trying to run a SVAR and I need to correctly order my variables in terms of contemporaneous effects. If I want output to contemporaneously affect interest rates, but not interest rates contemporaneously affect output, when I dictate the Cholesky order in the impulse response part of Eviews, should I write:
Cholesky order: interest rate, GDP
Or Cholesky order: GDP, interest rate
I appreciate your help.
Tom
tslay
Re: Urgent question about Cholesky Ordering
Postby tslay » Tue Feb 23, 2010 4:58 pm
Hi there,
I was looking for the answers to this question as well. Here's what I was told - hope it helps:
When you run the variance decomposition using Cholesky decomposition, the results will tell you which variable affects which contemporaneously. The Cholesky decomposition uses a lower triangular matrix so the error term with 100% in the first period does the affecting, I believe.
Cheers.
