It seems that EViews stores file paths in its .edb databases... for example this is a snippet of the plaintext of the database file:
[History] Imported from 'C:\Users\.../..../.../.../file.txt' Modified: 2014Q3 2200Q4
Is there a way to create the databases without this data? If not is there a way to remove it? I tried a regular expression to excise the text but the database became corrupted.
Best,
Luke
Filepath metadata in EViews databases
EViews Chris
Re: Filepath metadata in EViews databases
It's not really the database - it's that EViews objects often contain information about how they were generated in a 'history' section in the label view of the object. (Choose View/Label from the series menu to see a table containing the descriptive information attached to a series). You'll also see the same information saved inside an EViews .wf1 workfile.
You can clear this out *before* you store an object into a workfile or database using a command like:
myseries.clearhistory
where myseries is the name of the series.
Once the information is in a database, it's actually hard to get rid of. You can't directly modify the file with an external program because EViwes keeps checksums on all objects stored in a database (so that any damage to the file is detected quickly). I'm afraid you'd probably have to read the objects back into EViews, clear out the history then write them out again.
myseries.clearhistory worked in EViews 8.1, but no longer works in EViews 9.5.
Is this a known bug, or is there a new option in EViews 9.5?
Thanks,
Tim
Thanks,
Tim
Works for me:
wfcreate m 1990 2000
series y=nrnd
y=3
y=4
y=nrnd
y.clearhistory
show y.label
Thanks for the reply Gareth.
Sorry, I should have been clearer.
I use the import command to read data from a file and create many series including "rff".
Then the following:
rff.clearhistory
store(d=dbout) rff
Creates a database with a Remarks line:
[Remarks] Imported from 'C:\Users\USERID\AppData\ev_temp\fame2txt.txt
When I do the same thing with EViews 8.1, there are no Remarks in the database.
Thanks,
Tim
Then the following:
rff.clearhistory
store(d=dbout) rff
Thanks,
Tim
Use .clearremarks if you want to clear remarks.
Thanks Gareth. I didn't see clearremarks in the documentation.
So does .clearremarks do the same thing as .labels(c) ?
Tim
Tim
