problem with ARIMA
zohreh
problem with ARIMA
Postby zohreh » Sat Nov 15, 2014 11:12 am
I want to use ARIMA to forecast. At first I used ADF test and it shows the variable is I(1). But for determining the order of AR and MA when I use correlogram for first difference of variable it shows there is no order of AR and MA. now my problem is how should I estimate ARIMA? and how should I determine the order of MA and AR?
trubador
Did you use forum search?
Re: problem with ARIMA
Postby trubador » Mon Nov 17, 2014 2:57 am
Your variable might be a "white noise" series, in which case you cannot build an ARIMA model.
zohreh
Postby zohreh » Tue Nov 18, 2014 5:56 am
I attached data, please find them below and if it is OK please guide me what is the order of AR and MA?
Data.xlsx
(9.22 KiB) Downloaded 266 times
