I'm using "pagesave" to save one or several series to a specific range (rows-columns) in Excel files. trying to use the same command to save a vector of coefficients or the coefficients directly does not work because EViews says the object I'm trying to save "is not a series". I could use the "vector.write" command but that does not allow me to specify a specific range (row-column combination).
Is there a way to write a vector to a specific range in an Excel file?
Thanks!
~~Alois
write coefficients/vector to specific xlsx row-column
Re: write coefficients/vector to specific xlsx row-column
Unfortunately not.
