Roll addin ADVROLL
wjgatt
Roll addin ADVROLL
Postby wjgatt » Fri Oct 24, 2014 12:52 am
I have some code which makes use of the (simple) rolling regression addin, and it works great.
I've been trying to use the advanced rolling window addin, but despite the fact that I set the 'type' (=2, anchored at start), and the list of coefficients which are allowed to vary, it still prompts me with a dialog to choose.
I am doing this in a loop for 81 equations, so I cannot do it manually via the Procs menu. Any help with this would be greatly appreciated.
The code I am using (within the loop using the control variable !i) is the following:
eq_index{!i}.advroll(type=2, c g{!i}(-1) g{!i}(-12), start=1997m1, end=2014m1, pval, coef)
I am using the update from the post by Gareth: http://forums.eviews.com/viewtopic.php?f=23&t=2130
Thank you
W
Re: Roll addin ADVROLL
Postby EViews Gareth » Fri Oct 24, 2014 6:09 am
There is no command line interface to advroll.
wjgatt
Postby wjgatt » Fri Oct 24, 2014 7:10 am
I figured as much, but then what is the attachment on the tread (http://forums.eviews.com/viewtopic.php?f=23&t=2130) for?
It looks like a set of commands for either roll, or advroll: (type=2, start=..., etc)
Postby EViews Gareth » Fri Oct 24, 2014 7:13 am
Looks like they were removed.
boyboy
Postby boyboy » Fri Dec 19, 2014 10:43 pm
what is the formula for rolling regression? What is the minimum observation for rolling? I used 60 observations but the software said the observation is not enough.
Return to “Add-in Support”
