Eviews stops working when sorting series in graph
Posted: Mon Oct 20, 2014 4:45 am
by tvonbrasch
If you open the graph object gr_pw4 in the attached workfile, and press object, view options and sort, Eviews stops working.
I have Eviews 8.1, build oct 14.
What is causing this?
Re: Eviews stops working when sorting series in graph
Posted: Mon Oct 20, 2014 10:29 am
by EViews Jason
It will be fixed in the next patch. EViews will error in future versions.
Were you just reporting the crash or did you also really want to sort? If you did want to sort, what were you expecting the output to look like?
Posted: Mon Oct 20, 2014 11:03 pm
by tvonbrasch
Hi Jason
Yes I would like to have the graph sorted. Is there an easy way of doing this?
Posted: Wed Oct 22, 2014 9:23 am
by EViews Jason
Correct me if I am wrong, but in that particular graph you are graphing a single value (such as the means per country).
Sorting in graphs normally means to sort the data in ascending or descending order. Since you are only graphing a single value, what would you like sorting to do?
Posted: Thu Oct 23, 2014 2:47 am
by tvonbrasch
you are correct. now, when i merge the graphs, i merge them according to their value:
- gr_pw4.jpg (43.63 KiB) Viewed 5506 times
Posted: Thu Oct 23, 2014 2:21 pm
by EViews Jason
The order of the series in the graph depends upon the order in which they are placed in to the group from which the graph was made. This cannot be changed. We'll investigate ways we could make sorting the series order of a group easier
