I was wondering whether there is a way to specify the number of lags in a VAR in, say, a scalar (or any other object), and then to refer to it in the code?
Something like:
scalar L=3
Var test.ls 1 L variable1 variable2
Obviously the above is not working, otherwise I wouldn't have to post this thread :).
I have a lot of different VARs to estimate and this would make putting the results in tables so much more efficient.
Thanks!
VAR - specifying number of lags by referring to scalar/...
Re: VAR - specifying number of lags by referring to scalar/.
Normally you'd use a program variable rather than a scalar object, so it would be:
But if you really want to use a scalar object, you can do:
!L=3
Var test.ls 1 !L variable1 variable2
scalar L=3
Var test.ls 1 {L} variable1 variable2
