Problem with removing ticks
When i use the commands on the attached graph object
gr_p2_nor_d41t43.axis(a) ticksnone
or
gr_p2_nor_d41t43.axis(all) ticksnone
the ticks on the top part are not removed. They were removed when I used this command in Eviews 8. Now I have updated to Eviews 8.1.
However, if I use the command
gr_p2_nor_d41t43.axis(t) ticksnone
the ticks are removed. Is this a bug?
Ticksnone
Ticksnone
- Eviews_graph_problem.WF1
- (10.92 KiB) Downloaded 263 times
Re: Ticksnone
