All data is set to NA
Posted: Mon Sep 22, 2014 12:46 am
by Viviane
I am working a lot with EViews at the moment, and im having so trouble with my data workfile.
Whenever i open a workfile without opening EViews first (so out of my documents folder) all the data is set to NA. When i close it again and open the same document through EViews the data is set correctly. Whenever all the data is set to NA, i can not make a series with any values in it. I tested this with "genr x = 5" but it still says NA. This makes me think it has something to do with the settings.
Today i wanted to try something in EViews, so i wanted to make a "series x = 5" in an empty undated workfile with 50 observations. But when i opened x, it only said NA. And this time i can not fix it by opening in EViews, because i did not open anything.
Does anyone know wheter this has anything to do with the settings? Or what else it could be?
Re: All data is set to NA
Posted: Mon Sep 22, 2014 6:25 am
What is the version and build date of your copy of EViews? (Help/About)
Posted: Mon Sep 22, 2014 6:27 am
by Viviane
Version 7.1
build sep 10 2010
Posted: Mon Sep 22, 2014 6:28 am
You might want to apply the free updates and see if the problem goes away.
