Splitting up vectors
tode
Postby tode » Wed Jul 08, 2009 5:56 am
Dear all,
I have estimated a pooled estimation (32 firms over 53 weeks) in the following manner:
firmpool.ls y? @perreg 1 @perreg beta?
Now, I have 106 estimated coefficients (for every exogenous one estimate in each period). Following the Fama-MacBeth procedure, I am interesed in the averages of those estimates, whereas I have one coefficient vector by means of the following command:
firmpool.updatecoef coef(106) gamma = c
My question is now, how to split the gamma vector with 106 rows in 2 vectors (gamma0 and gamma1) with 53 rows each (the first 53 being for the intercepts, the second 53 for the risk premia) in order to transform these 2 vectors in time series using the "mtos"-command and then be able to calculate the averages and so forth.
Additionally, I would like to know, whether anybody knows how to get a vectorization of a diagonal matrix (the coefficient covariance matrix...) to apply the same methodology for this vector then.
Any help is highly appreciated,
many thanks in advance
Tobi
Re: Splitting up vectors
Postby EViews Glenn » Wed Jul 08, 2009 9:32 am
This should do the trick
vector gamma1 = @subextract(c,1,1,53) vector gamma2 = @subextract(c,54,1,106) vector vars = @getmaindiagonal(firmpool.@coefcov)
tode
Postby tode » Wed Jul 08, 2009 11:09 am
Thank you, this was similar to that what I figured out in the meantime. It worked perfectly.
I still have two questions:
1) Did I understand the estimation right, when I said that the 53 estimates for each exogenous are the estimates from the cross-sectional regression in every point t between 1 and 53?
2) Is it possible to conduct inference with the mean of the gamma series in EViews - as Fama-MacBeth propose, or do I have to do it by hand?
Thanks in advance,
Tobi
Postby EViews Glenn » Thu Jul 09, 2009 9:39 am
Since you are fully interactive in time, these should give you the equivalent of 53 cross-section regressions.
I'm not familiar with the Fama-McBeth methodology. From my 30 second Google search it sounds like you then want to take the vectors and use them in regression analysis. You can do this by creating a new workfile of length 53, copying the vectors over there, then using mtos to convert to series.
I don't know how the Fama-McBeth corrects for the estimation uncertainty in these coefficient values, so I really don't know what needs to be done in that regard.
tode
Postby tode » Thu Jul 09, 2009 10:56 am
ok, thank you for your effort.
