A new correlation coefficient
trubador
Did you use forum search?
Postby trubador » Fri Aug 29, 2014 4:46 am
In a recent article, authors have proposed a new correlation coefficient for time series data that measures the distance between two subsequent data points by taking the lag difference into consideration. They demonstrate that the new correlation coefficient better captures the direction of the covariation of the two variables over time.
The code below shows the computation of new coefficient as well as the simulations outlined in the article (i.e. vis-a-vis the ordinary correlation):
'Reference: Erdem, O., Ceyhan, E. and Varli, Y. (2014). A new correlation coefficient for bivariate time-series data, Physica A, 414, pp. 274–284 mode quiet !nobs = 100 '# observations !nsim = 10000 '# simulations wfcreate u !nobs 'create an unstructured workfile !case= 1 '(1 -> Stationary, 2 -> Random walk, 3- > Cointegrated) matrix(!nsim,2) compare 'store the results 'generate null series series x series y 'Run the simulations smpl @first+1 @last !rho = 0 for !i = 1 to !nsim if !case = 1 then x(1) = @rnorm 'random initialization y(1) = @rnorm x = @rnorm y = @rnorm else if !case = 2 then x(1) = @rnorm y(1) = @rnorm x = x(-1) + @rnorm y = y(-1) + @rnorm else x(1) = @rnorm y(1) = @rnorm !a=0.8 x = x(-1) + nrnd y = !a*x + nrnd endif endif 'Compute the ordinary correlation compare(!i,1) = @cor(x,y) 'Compute the proposed new correlation call newcor(x,y,!rho) compare(!i,2) = !rho 'Watch the progress statusline !i of !nsim next 'Histograms of simulated correlations freeze(mode=overwrite,histograms) compare.distplot show histograms smpl @all 'Local subroutine that computes the proposed correlation coefficent subroutine local newcor(series x,series y,scalar rho) series dx = d(x) series dy = d(y) series dxy = dx*dy group g.add dx dy local smpl smpl @all if @rnas(g)=0 'data may include missing values !Ax = @sqrt(@sumsq(dx)/@obssmpl) !Ay = @sqrt(@sumsq(dy)/@obssmpl) !Axy = @sum(dxy)/@obssmpl rho = !Axy/(!Ax*!Ay) endsub
