Viewing actual forecast number (instead of Forecast graph)
jasonleewkd
Hi, I click on Forecast and it shows my forecast graph, but where can I see the actual forecast numbers (for purposes of pasting into excel)? I understand I can go to View >> Actual, Fitted, Residual >> Actual, Fitted, Residual Table and see the actual numbers for the fitted and actual but not the forecast. Help appreciated! Thanks.
Re: Viewing actual forecast number (instead of Forecast grap
When you perform the forecast, it asks you to enter a name for the forecast series (defaulted to the name of the dependent variable with an f on the end).
There will be a new series in the workfile with that name. You can open that series to look at the numbers
