I have the following equation:
"TDA=c firm_size profitability tangibility current_ratio dep_totalassets earnings_volatility year08 year09 year10 year11 year12 year13"
Where yearXX are dummies and after I remove them the regressions run without problems. Also when I exclude the constant C, there is no problem. So it appears there is multicollinearity between the dummies and C.
I need t run OLS, fixed & random effect on the equation above. It is panel data, balanced for 6 years.
This is my first time with EViews, would appreciate any help or advice. I will check previous post as well.
Rado
ps I am using EViews 7.2
Near Singular Matrix, dummy trap
- Work_File.WF1
- (159.68 KiB) Downloaded 266 times
Re: Near Singular Matrix, dummy trap
As you surmise, there is perfect multicollinearity between the year dummies and the constant. Leave one out.
Thank you, actually it is only the last dummy year13, I will just drop it.
You can probably drop any year, but dropping the last one is fine.
