Trouble using @pval
Gabriel de Kock
Trouble using @pval
Postby Gabriel de Kock » Tue Jul 08, 2014 3:14 pm
I'm trying to save results from a cointreg estimation, but get ab error message when I try to use @pval to save p-values into a previously-created matrix. Here is a snippet of code:
exp_mod(i,1) = c(1)
exp_mod(i,2) = @tstats(1)
exp_mod(i,3) = @pval(1)
I get the following error message:
@pval is an illegal or reserved name in “exp_mod(i,3) = @pval(1)”
I get the same message when I try to use
exp_mod(i,3) = @pvals(1)
Please tell ne what I'm doing wrong here.
Re: Trouble using @pval
Postby EViews Glenn » Tue Jul 08, 2014 3:46 pm
You need to use @pval off of a named equation, as in
exp_mod(i,3) = eq1.@pval(1)
Gabriel de Kock
Postby Gabriel de Kock » Wed Jul 09, 2014 6:37 am
Thank you very much. It's odd, though, that t-stats are not treated in the same way. And I did not see anything in the command reference, e.g., to make that clear.
Postby EViews Gareth » Wed Jul 09, 2014 7:03 am
You should always use objectname.datamember when accessing data members. Even tstats
Postby EViews Glenn » Wed Jul 09, 2014 7:42 am
Note that the documentation doesn't really describe the method that the original poster used. It is legacy behavior.
