Is there a way to declare an equation without estimating it? i.e.
equation eq_one.(?) a = c(1) + c(2)*b
The (?) is usually the estimation method...
Declare equation without estimating
Re: Declare equation without estimating
You can declare an equation (create a blank equation object). You cannot specify (set the expression to be estimated) an equation without estimating.
