issue with advanced rolling regression
the advanced rolling regression function seems to have gone completely haywire (it has been working perfectly until this morning). Specifically When i anchor at the start date (1988m11), and run it to the end date (2013m12) i see eviews calculating from start to the end dates. However when i look at the coefficients , there are n/a from 2005 onwards. As a test i reapplied the rolling regression to an advanced roling regression i performed yday (which produced coefficients from 1988 to 2013). The same problem occurred, namely now the coefficents were only produced up to 2005 with n/a afterwards. Has anyone come across this before? tks...
Re: issue with advanced rolling regression
i should add that this problem (coefficients being n/a after 2005) is occurring every time i run any advanced regression in which you anchor the start date. The other advanced rolling regression functionality is still working fine..
If you believe something has happened to your copy of the add-in, you can always re-download and install it.
yep, already tried that..plus i also got my IT guys to reinstall eviews..same problem remains..irrespective of whatever range i enter now it will no longer calculate values for the ranges im entering....its as if this function / eviews has become corrupted in some way (please note that i have been using this function repeatedly for months prior to this)..would it be possible to send someone the eviews file by email so they could take a look? tks
You can post it here
