Hi all,
Can anyone help to plot regression lines graph of Panel data, Eviews 8
I used the following model of Panel data and want to plot regression lines in same graph :
Tobin's q = (c0) + (c1)*manager ownership(mo)+(c2)*mo^2+(c3)*mo^3+(c4)*control value1+(c5)*control value2+error term (1)
Capital structure=(c0) + (c1)*manager ownership("mo")+(c2)*mo^2+(c3)*mo^3+(c4)*control value1+(c5)*control value2+error term (2)
I tried to plot the above 2 regression lines in the same graph, but can not found any tool bar in eView can plot the graph. From the user guide, it shows us how to plot bar of Panel data but can not plot a regression line.
Any one call tell me the steps to plot regression lines of Panel data in the same graph, sample attached.
Thank you!!!
Anita
How to plot regression line graph of Panel data
- plot regrression line sample271.pdf
- (52.73 KiB) Downloaded 321 times
Re: How to plot regression line graph of Panel data
I think what you're trying to do is plot the fitted values from a regression. Just estimate the equation/regression, then hit the forecast button to create the fitted values. Then graph the forecast series.
Thank you Gareth.
I tried but I don't know why there is 2 line and not in "N" shape.
According to the Result of OLS on equation (1) and (2), the line is in "N" shape but it is not.
Please find the result of OLS for your comment and tell me any missing steps. I need to find out the value of turning points in above 2 regression line.
- Result of OLS on eq(1) and eq(2).pdf
- (6.26 KiB) Downloaded 365 times
I don't understand what you're asking, or what that picture is supposed to show me.
Gareth, thank you!!
The picture (graph of the regression line of Panel data) is attached.
I also attach descriptive analysis for your information.
- Descriptive analysis of Q1.pdf
- (27 KiB) Downloaded 351 times
- Descriptive analysis of Q2.pdf
- (26.77 KiB) Downloaded 313 times
- (52.73 KiB) Downloaded 363 times
