Seasonal Adjustment [series with positive & negative values]
etrachan
Postby etrachan » Wed May 07, 2014 9:14 am
I am having a problem adjusting my data for seasonality.
My time series contain both positive and negative values (e.g. % quarterly budget deficit).
When attempting to perform the Census X-13 seasonal adjustment (using basic auto options) I get an error message:
"ERROR: Multiplicative or log-additive seasonal adjustment cannot be done with a series with zero or negative values. No seasonal adjustment this run."
Any tips to overcome this?
Here is an example of my workfile:
bd.wf1
Quarterly Budget Deficits %
(12.69 KiB) Downloaded 324 times
Thanks in advance!
Re: Seasonal Adjustment [series with positive & negative val
Postby EViews Glenn » Wed May 07, 2014 9:34 am
Use additive seasonal adjustment. Pseudo-additive might work as well, I'm not sure how the latter is computed.
etrachan
Postby etrachan » Wed May 07, 2014 10:18 am
I will try using only the additive seasonal adjustment method in the relevant menu of the Census X-13 option.
Thank you very much.
