GURoot
abdnfinancestudent
GURoot
Postby abdnfinancestudent » Fri Apr 25, 2014 5:06 am
I have a question in regard tot he GURoot add-in. When I try using the Dickey-Fuller GLS unit root test I get the following error "DFGLS is an unrecognised option for UROOT in "do_resilts08,Append LCPIE.UROOT(const, DIF=0, DFGLS, info=AIC, maxlag=*, save=_temp01)"". The ADF test is working properly and it delivers the same results as the in-build test in Eviews 8. I am using a panel workfile and I was trying to use the DFGLS test also.
Regards,
Boz
clubmed
Re: GURoot
Postby clubmed » Thu Jan 14, 2016 9:30 am
can you extend this add-in to use intercept+trend+ quadratic trend for ADF, i have modifie the programme but any idea, can you help me please, the code is attached below
guroot with intecept+trend+sqtrend.rar
(1.2 KiB) Downloaded 753 times
Return to “Add-in Support”
