stability in VECM
christine
stability in VECM
Postby christine » Sun Jun 21, 2009 11:31 am
Dear all,
I'm working on my final paper and i have met some difficulties when estimating a VECM. Using Johansen cointegration test, I've discovered one cointegrating equation between the variables. After that, I estimated the VECM. I've read in some econometrics books that after i estimate the VECM i shall employ a stability test using this path: LAG STRUCTURE- AR ROOTS TABLE. And the roots should be inside the unit circle. However, in my case, the first root is 1 and the others are less than 1. Does this mean that the results I've obtained employing VECM are not good? Or should I have employed the stability test on the VAR from Johansen cointegration test.
Thanks a lot
Christine
rosen
Re: stability in VECM
Postby rosen » Fri Aug 07, 2009 1:07 am
hi
does any body have a programme for running recursive residual test or cusum test of a svecm, its urgent.
thanks
rosen
mirza kaleemullah
Postby mirza kaleemullah » Sun Sep 01, 2013 11:05 am
hi Christen
i hope that u have addressed this issue. I am indulged in the same thing that VECM is not stable and every time in estimation same vecm, it gives new results.
anybody there plz?
regards
