Page 6 of 16
Re: How to enter data into a panel workfile.
Posted: Sat Apr 13, 2013 6:36 pm
by duynguyen88vn
please help me! How to enter this data into a panel workfile??????
Posted: Sat Apr 13, 2013 9:51 pm
Could you describe it?
Posted: Mon Apr 15, 2013 1:25 am
by duynguyen88vn
i want to estimate : payout c grownth de cash......
used to random effect model, fix effect model
many thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted: Mon Apr 15, 2013 8:10 am
You'll have to use a program to bring that in as a panel.
In EViews 8:
wfopen c:\temp\sheetpanel.xls byrow range="TANGIBILITY!a1:e101" @rename * *_tang
import c:\temp\sheetpanel.xls byrow range="PAYOUT!a1:e101" @rename * *_payout
import c:\temp\sheetpanel.xls byrow range="GROWTH!a1:e101" @rename * *_growth
import c:\temp\sheetpanel.xls byrow range="SIZE!a1:e101" @rename * *_size
import c:\temp\sheetpanel.xls byrow range="EPS!a1:e101" @rename * *_eps
import c:\temp\sheetpanel.xls byrow range="TAX!a1:e101" @rename * *_tax
import c:\temp\sheetpanel.xls byrow range="DE!a1:e101" @rename * *_de
import c:\temp\sheetpanel.xls byrow range="CASH!a1:e101" @rename * *_cash
pagestack(page=panel) ?_cash @ ?*
rename _* *
Posted: Mon Apr 15, 2013 5:47 pm
by duynguyen88vn
hic. i used to run Eviews 6. can i run your wf by eviews 6?
can you send to me eviews file of this data?
Posted: Mon Apr 15, 2013 6:04 pm
You're probably best off just re-arranging the data in Excel.
Posted: Mon Apr 15, 2013 6:23 pm
by duynguyen88vn
because very large amounts of data . I re-encoded it takes a lot of time!
Can i do it in Eviews 7?
Posted: Mon Apr 15, 2013 7:16 pm
by duynguyen88vn
Can you send to me eviews of this sheetpanel!!!!!!!!!!!!!! thanks you very much!!!!!!!!!!!
Posted: Wed Apr 17, 2013 2:46 pm
by Dxbugs
Hi Gareth,
I was trying to do the exercise by using the second data. I downloaded it and tried in version 7.1.
After doing the stacking in new page, I didn't get the id01 and id02! so I can't continue to the next step: unstacking..variable etc.
What seems to be the problem?
Thanks.
Dx
Posted: Wed Apr 17, 2013 3:24 pm
In EViews 7, ID01 is VAR01
Posted: Wed Apr 17, 2013 3:54 pm
by Dxbugs
Thanks.
I think it is different.
If you look at you posted workfile is says:
c
id01
id02
resid
state
variable
yr
What I got after new stacking:
c
resid
state
var01
variable
yr
there is no id01 and id02?
Posted: Wed Apr 17, 2013 5:26 pm
Use VAR01
Posted: Wed Apr 17, 2013 5:49 pm
by Dxbugs
Use VAR01
Hi Gareth,
attached is my data, formatted the same as your second example. I am new to eviews that is why I am trying to learn the basics..
I really want to know how to convert this excel format to eviews panel data..If possible, can you kindly give me step by step procedure to convert this to panel data? I may actually add some more variables on this later on.
I am using version 7.1
Thanks in advance.
Best.
Dx
Posted: Wed Apr 17, 2013 7:06 pm
Use "num?" as the stacking id in the page stacking part.
Use "firms var" as the unstacking id, and "var01" as the obs id in the unstacking part.
Posted: Wed Apr 24, 2013 6:03 am
by Qmars
Hello Gareth,
I am using the second type of format on "Re: How to entre data into a panel workfile.". On Panel_STK workfile page, I type alpha var2..... in the command pane to create a new alpha series containing valid names. Once i stroke enter, a messages appears asking if I want to delete "variable" series. By tapping on "yes"tab, the "variable" series disappears but var2 series does not create. Any idea what I am doing wrongly? Thanks
