Multi-step ahead forecast
Re: Multi-step ahead forecast
Postby EViews Gareth » Fri Jul 18, 2014 7:59 am
The code you gave is for an EViews program. You'll need to run it in a program. Click on File->New->Program, then type it in there, and hit the run button.
Nicole
Postby Nicole » Fri Jul 18, 2014 10:24 am
Thank you so much Gareth, you are a lifesaver! I have been able to successfully run the program :)
Nicole
Postby Nicole » Wed Jul 30, 2014 5:40 am
Hi again,
I have further question regrding my forecasting using GARCH models.
I want to try to forecast over different time horizons (eg.1, 5, 21 and 252 days ahead). In order to do this I am using the program I specified in my previous post.
However, when using a rolling window of 1, I do not get the same results as I do when I am using the drop down menues. I am staring to wonder if I have completely misunderstood what I am doing :?
Do you mind explaining to me what eviews actualy does when I use the drop down menues (choosing static forecast), or how I should go about forecasting different time horizons?
I have attached the program I am using, when trying to forecast over 5 days.
As usally all help is much appreciated! :)
'set window size'
!window=4070
'get size of workfile'
!lenght=@obsrange
'declare equation for estimation'
equation eq01
'set step size'
!step=1
'calculate number of rolls'
!nrolls=@floor((!lenght-!window)/!step)
'matrix to store coefficient estimates'
Matrix(5,!nrolls)coefmat 'where 5 is the number of coefficients
'series to store forecast estimates
series fcast
series fcastse
series fcastvar
'catching start and end points
%start= "@first"
%end= "@last"
'variable keeping track of how many rolls we've done
!j=0
'move sample !step obs at a time
for !i=1 to !lenght-!window+1-!step step !step
!j=!j+1
'set sample for estimation period
%first=@otod(@dtoo(%start)+!i-1)
%last=@otod(@dtoo(%start)+!i+!window-2)
smpl {%first} {%last}
'store coefficients
colplace(coefmat,eq01.@coefs,!j)
'1-period-ahead forecast
%5pers=@otod(@dtoo(%start)+!i+!window-1)
%5pere=@otod(@dtoo(%start)+!i+!window+4)
'set smpl for forecasting period
smpl {%5pers} {%5pere}
' forecast with command *fit*
eq01.fit(f=na) g_f1 g_se g_var
' store forecasts
fcast=g_f1
fcastse=g_se
fcastvar=g_var
'calculate RMSE
scalar rmse=@rmse(returns, fcast)
‘calculate MAE
Scalar mae=@mae(returns, fcast)
Postby EViews Gareth » Wed Jul 30, 2014 8:13 am
I'm not sure I understand what you're asking.
Nicole
Postby Nicole » Wed Jul 30, 2014 8:29 am
Sorry for not being clear enough. Basically, I thought that when I was doing a static forecast from the drop down menu I was forecasting 1-step ahead, meaning that as I am using daily data I would be forecasting 1 day ahead..
However, when I tried to adjust the program I attached to my previous post for it to become a 1 day rolling window, my outcomes are completely different. Have I misunderstood what Eviews is doing in the drop down menu or is my program not doing what I want it to do (forecast over different horizons)?
The drop down menu
Postby EViews Gareth » Wed Jul 30, 2014 8:36 am
create u 10000 series returns=nrnd series x1=nrnd equation eq01.arch returns c x1 'set window size' !window=400 'get size of workfile' !lenght=@obsrange 'declare equation for estimation' equation eq01 'set step size' !step=1 'calculate number of rolls' !nrolls=@floor((!lenght-!window)/!step) 'matrix to store coefficient estimates' Matrix(5,!nrolls)coefmat 'where 5 is the number of coefficients 'series to store forecast estimates series fcast series fcastse series fcastvar 'catching start and end points %start= "@first" %end= "@last" 'variable keeping track of how many rolls we've done !j=0 'move sample !step obs at a time for !i=1 to !lenght-!window+1-!step step !step !j=!j+1 'set sample for estimation period %first=@otod(@dtoo(%start)+!i-1) %last=@otod(@dtoo(%start)+!i+!window-2) smpl {%first} {%last} 'store coefficients colplace(coefmat,eq01.@coefs,!j) '1-period-ahead forecast %5pers=@otod(@dtoo(%start)+!i+!window-1) %5pere=@otod(@dtoo(%start)+!i+!window+4) 'set smpl for forecasting period smpl {%5pers} {%5pere} ' forecast with command *fit* eq01.fit(f=na) g_f1 g_se g_var ' store forecasts fcast=g_f1 fcastse=g_se fcastvar=g_var 'calculate RMSE scalar rmse=@rmse(returns, fcast) ‘calculate MAE Scalar mae=@mae(returns, fcast) next smpl 400 @last
If I then open up eq01, hit the forecast button and select "static" as the forecast type, then open up the series returnsf and fcast, they're identical.
Nicole
Postby Nicole » Wed Jul 30, 2014 9:09 am
I am sorry for being so slow, but I still don't get it right... :oops:
I still do not get the same results by trying the two methods and my RMSE and MAE end up being the exact same number when I am trying to use the commands.
create u 4966 (this number is the total number of observations)
series returns=nrnd
series x1=nrnd
'set window size'
!window=4070 (this is my in-sample period)
!lenght=@obsrange
equation eq01
'set step size'
!step=1
series fcast
series fcastse
series fcastvar
%start= "@first"
%end= "@last"
!j=0
!j=!j+1
'store coefficients
%1pers=@otod(@dtoo(%start)+!i+!window-1) (%1pers because I am trying a 1-day ahead forecast)
%1pere=@otod(@dtoo(%start)+!i+!window+0)
smpl {%1pers} {%1pere}
' store forecasts
fcast=g_f1
fcastse=g_se
fcastvar=g_var
'calculate RMSE
‘calculate MAE
smpl 4070 @last
brent-b1_ice.wf1
Workfile
(450.65 KiB) Downloaded 773 times
Postby EViews Gareth » Wed Jul 30, 2014 9:16 am
I get the same results.
Nicole
Postby Nicole » Wed Jul 30, 2014 9:26 am
The same results by trying to use both methods (using my code)?
When doing it from the drop down menu I get RMSE=0.993259, MAE=0.797992
When I use the code RMSE=MAE=0.895579
Is there something wrng with my code? :?
Nicole
Postby Nicole » Thu Jul 31, 2014 1:47 am
Hi Gareth,
I am sorry to bother you, but I am really struggling to figure out what I am doing wrong.
For some reason my RMSE and MAE come out identical and both inconsistent with the results I get when using the drop down menu.
When I try the example you posted I seem to get it right, but when trying to apply it to my workfile it doesn't work :(
Could you please have a look at my code as I am unable to figure out what I am doing wrong?
Postby EViews Gareth » Thu Jul 31, 2014 7:54 am
Let's ignore the RMSE and MAE for the moment. You said that the actual forecast series are different. Is that true?
Nicole
Postby Nicole » Thu Jul 31, 2014 10:14 am
That is correct. Can this be caused by me using the rolling window?
I have attached a screen shot of my forecasts using the two approaches. ReturnsF is the one when I used the drop down menu, while Fcast is the one where I used the program.
Screenshot (65).png (176.74 KiB) Viewed 17377 times
Postby EViews Gareth » Thu Jul 31, 2014 10:27 am
Post the exact program you are using. Give precise details on exactly what you are doing when you generate the forecast.
Nicole
Postby Nicole » Thu Jul 31, 2014 11:05 am
When using the dropdown menu I estimate the simple GARCH(1.1) model by including "returns c returns(-1)" in the mean equation and nothing in the variance equation. I estimate my in-sample for 2/1/1995 12/30/2009, which equals 4070 observations. Then I press forecast - static - forecast sample "12/31/2009-6/13/2014"-deselect the "insert actuals for out of sample".
When trying to conduct a 1-step ahead forecast (1 day as I am using daily data) I use the following program:
'set window size' (my in-sample window)
!window=4070
!lenght=@obsrange
'declare equation for estimation' (this is a standard GARCH(1.1) with a constant and a lagged value in the mean equation, which i have named eq01)
equation eq01
'set step size'
!step=1
series fcast
series fcastse
series fcastvar
%start= "@first"
%end= "@last"
!j=0
!j=!j+1
'store coefficients
'1-period-ahead forecast (%1 because i want to forecast one day ahead)
' store forecasts
fcast=g_f1
fcastse=g_se
fcastvar=g_var
'calculate RMSE
'calculate MAE
Postby EViews Gareth » Thu Jul 31, 2014 11:15 am
You're missing some Next statements.
