Favar QUESTION
Re: Favar QUESTION
thank you , Dakila !!i am grateful ! we are lucky to be able to benefit from your help !
i followed your instructions and i obtain the impulse response matrix(for shock egal to -0.25) , i use the option graph and i obtain the graphs of impulse response without confidence intervals , the axis 0 and the name of the selected variables (see workfile). what should i do to get them (like figure 01 in your exple) ?
for the conditional forecast,you tell me i should transform for exple series2 to the non standardized on . i must do it :
-before i estimate eq01 ?
- before i forecast the factors ?
- before i forecast series2 ?
i transform only the selected variable (series2) , NOT the series contrained (ffr). true ?
THANK YOU very much !
Salima
Salima
- graph.wf1
- (22.83 KiB) Downloaded 1150 times
Re: Favar QUESTION
You should do the same things for the confidence interval. For example:what should i do to get them (like figure 01 in your exple) ?
matrix irf_ub=irfxmat_ub01/irfxmat_ub01(1,1)
irf_ub = irf_ub*(-0.25/ffr_std) ' upper bound
matrix irf_lb=irfxmat_lb01/irfxmat_lb01(1,1)
irf_lb = irf_lb*(-0.25/ffr_std) ' lower bound
After the conditional forecast you should transform for expel series2for the conditional forecast,you tell me i should transform for exple series2 to the non standardized on . i must do it :
Yes that is true.i transform only the selected variable (series2) , NOT the series contrained (ffr). true ?
Re: Favar QUESTION
Thank you for your answer, Dakila !
i obtain the ifr with confidence interval.
i transform some of my variables to induce stationarity .when i perform 'the conditional forecast ',i have for exple the conditional forecast of the
dlog pib ( i transform this variable back to the non-standardized one).
i would like to obtain the conditional forecast of the real value (without transformation ). in general ,i can applied the formula
Tx+1 = Tx *e(dlogpib) . how can i traduce this formula to employ it in eviews ?
thank you in advance !!
SALIMA
SALIMA
Re: Favar QUESTION
hi Dakila !
can you add the transformation' second difference of log ' and 'first difference' please ? i have no stationary variables with dlog so i must use ddlog.
Thank you very much !!
salima Ouerk
phd student
salima Ouerk
phd student
Re: Favar QUESTION
Hi Dakila,
could you add the others possible transformations ? ( the fist difference ,the second difference and ddlog)
Thanks you very much for your answer !!
Salima Ouerk
Salima Ouerk
Re: Favar QUESTION
The impulses responses of the variables to an unexpected increase in ffr are to be interpreted in "pourcentage points " in the model ? for exple, changes in GDP are expressed in pourcentage point ? or in standard deviation ?
Re: Favar QUESTION
Note that the figures report impulse responses in standard deviation units.
Re: Favar QUESTION
hiThere is example file (favar_ex.prg) and instruction pdf file in the FAVAR add-in folder.
i can`t find this instruction pdf file!!! i extracted factors and i have x and y variables but i don`t know how i have to use them in eviews.
Re: Favar QUESTION
hi
i`m doing a favar analysis. i`v extracted factors and i have x and y variables. but i don`t know how i have to use them in eviews, i can`t find the instruction pdf file in add ins
Re: Favar QUESTION
C:\Users\...\Documents\EViews Addins\FAVAR\favar.pdf
HyeongjunKim
Re: Favar QUESTION
Hi. I downloaded the favarsf add-in, but I cannot find the example file (favar_ex.prg).Hi,Dakila, your suggestion is helpful. I am trying to follow the instruction to apply the FAVAR. However, I did the exactly same as the favar_ex, the software replied me with "factor01 is not the same length as the sample". Could you tell me what is wrong with it?There is example file (favar_ex.prg) and instruction pdf file in the FAVAR add-in folder.
1.Where can I find the example file?
2. What is the difference between the old favar add-in and the new add-in named favarsf? Does the new one also replicate the Bernanke et al(2005)?
Re: Favar QUESTION
This thread is about the favar add-in. The favarsd is written by another author. I don't know about the favarsf add-in
