Favar QUESTION
ouerk
Re: Favar QUESTION
Postby ouerk » Fri Jul 21, 2017 11:40 am
thank you , Dakila !!i am grateful ! we are lucky to be able to benefit from your help !
i followed your instructions and i obtain the impulse response matrix(for shock egal to -0.25) , i use the option graph and i obtain the graphs of impulse response without confidence intervals , the axis 0 and the name of the selected variables (see workfile). what should i do to get them (like figure 01 in your exple) ?
for the conditional forecast,you tell me i should transform for exple series2 to the non standardized on . i must do it :
-before i estimate eq01 ?
- before i forecast the factors ?
- before i forecast series2 ?
i transform only the selected variable (series2) , NOT the series contrained (ffr). true ?
THANK YOU very much !
Salima
graph.wf1
(22.83 KiB) Downloaded 1146 times
dakila
Re: Favar QUESTION
Postby dakila » Sat Jul 22, 2017 12:40 am
You should do the same things for the confidence interval. For example:
matrix irf_ub=irfxmat_ub01/irfxmat_ub01(1,1) irf_ub = irf_ub*(-0.25/ffr_std) ' upper bound matrix irf_lb=irfxmat_lb01/irfxmat_lb01(1,1) irf_lb = irf_lb*(-0.25/ffr_std) ' lower bound
Easiest way to draw the figure is copy the matrix to excel then draw the graph.
After the conditional forecast you should transform for expel series2
Yes that is true.
ouerk
Re: Favar QUESTION
Postby ouerk » Tue Jul 25, 2017 9:49 am
Thank you for your answer, Dakila !
i obtain the ifr with confidence interval.
i transform some of my variables to induce stationarity .when i perform 'the conditional forecast ',i have for exple the conditional forecast of the
dlog pib ( i transform this variable back to the non-standardized one).
i would like to obtain the conditional forecast of the real value (without transformation ). in general ,i can applied the formula
Tx+1 = Tx *e(dlogpib) . how can i traduce this formula to employ it in eviews ?
thank you in advance !!
SALIMA
dakila
Re: Favar QUESTION
Postby dakila » Wed Jul 26, 2017 1:05 am
what is Tx?
ouerk
Re: Favar QUESTION
Postby ouerk » Thu Aug 17, 2017 5:09 am
hi Dakila !
can you add the transformation' second difference of log ' and 'first difference' please ? i have no stationary variables with dlog so i must use ddlog.
Thank you very much !!
salima Ouerk
phd student
dakila
Re: Favar QUESTION
Postby dakila » Fri Aug 18, 2017 6:29 am
I will try
ouerk
Re: Favar QUESTION
Postby ouerk » Sat Aug 19, 2017 8:39 am
thank you very much !!
ouerk
Re: Favar QUESTION
Postby ouerk » Tue Oct 10, 2017 5:38 am
Hi Dakila,
could you add the others possible transformations ? ( the fist difference ,the second difference and ddlog)
Thanks you very much for your answer !!
Salima Ouerk
ouerk
Re: Favar QUESTION
Postby ouerk » Mon Nov 20, 2017 8:00 am
The impulses responses of the variables to an unexpected increase in ffr are to be interpreted in "pourcentage points " in the model ? for exple, changes in GDP are expressed in pourcentage point ? or in standard deviation ?
dakila
Re: Favar QUESTION
Postby dakila » Mon Nov 20, 2017 2:08 pm
Note that the figures report impulse responses in standard deviation units.
neda
Re: Favar QUESTION
Postby neda » Sat Oct 13, 2018 11:14 pm
There is example file (favar_ex.prg) and instruction pdf file in the FAVAR add-in folder.
hi
i can`t find this instruction pdf file!!! i extracted factors and i have x and y variables but i don`t know how i have to use them in eviews.
neda
Re: Favar QUESTION
Postby neda » Sat Oct 13, 2018 11:20 pm
hi
i`m doing a favar analysis. i`v extracted factors and i have x and y variables. but i don`t know how i have to use them in eviews, i can`t find the instruction pdf file in add ins
dakila
Re: Favar QUESTION
Postby dakila » Tue Oct 16, 2018 5:53 am
C:\Users\...\Documents\EViews Addins\FAVAR\favar.pdf
HyeongjunKim
Re: Favar QUESTION
Postby HyeongjunKim » Thu Mar 18, 2021 5:44 pm
Hi,Dakila, your suggestion is helpful. I am trying to follow the instruction to apply the FAVAR. However, I did the exactly same as the favar_ex, the software replied me with "factor01 is not the same length as the sample". Could you tell me what is wrong with it?
Hi. I downloaded the favarsf add-in, but I cannot find the example file (favar_ex.prg).
1.Where can I find the example file?
2. What is the difference between the old favar add-in and the new add-in named favarsf? Does the new one also replicate the Bernanke et al(2005)?
dakila
Re: Favar QUESTION
Postby dakila » Thu Mar 18, 2021 8:13 pm
This thread is about the favar add-in. The favarsd is written by another author. I don't know about the favarsf add-in
Return to “Add-in Support”
