Page 2 of 3
Re: simple OLS regression- F-statistic is not reported
Posted: Sat Aug 04, 2012 7:02 am
by startz
Gobble, just a reminder that--to someone outside your project--it appears you're running your regression backwards.
Posted: Sun May 26, 2013 5:57 am
by devi.lupita
I can verify that the bug has not been fixed.
So that you can get on about your work, I have done the following.
series rlag=r(-1) ls rlag c r
I've posted the results for you, but I'm 99% certain that you want
ls r c rlag
instead.
i also have the same problem. the F-statistic is not reported.
could you please elaborate the steps to add those code?
thanks in advance
Posted: Sun May 26, 2013 7:33 am
by startz
First thing, update your copy of EViews.
Posted: Mon May 27, 2013 8:45 am
by devi.lupita
I used EViews 6.0 at the first, and I didn't find the F-statistic and probabilty on my output.
Then I upgrade the version to 7.1 but there was no changed.
is there any other way to fix this?
Posted: Mon May 27, 2013 9:02 am
by startz
Apply the free update get to version 7.2 and see if that helps.
Posted: Mon May 27, 2013 7:09 pm
by devi.lupita
I've upgraded the version to 7.2, but it still didn't help.
This is the data pooled i used
This is the steps of the estimation
and this is the output
Maybe you could find my wrong when I do the steps of the estimation.
I really need the value of F-statistic and probability using very basic OLS regression method.
Posted: Mon May 27, 2013 7:56 pm
by startz
The problem is probably that you don't have a constant term.
Posted: Mon May 27, 2013 8:07 pm
by devi.lupita
I see. But, the constant term comes automatically after every estimation, doesn't it?
So, what's wrong?
I estimated my data using another method (both fix effect and random effect) and I got the constant term, F-statistic and probability as well.
What should I do to get those values in OLS method?
Posted: Mon May 27, 2013 8:13 pm
by startz
No, EViews does not include a constant term automatically. You need to include "C" as a variable if you want a constant term.
Posted: Mon May 27, 2013 8:22 pm
by devi.lupita
How can I make "C" as a variable?
where should I put the "C" to make it as a variable since there's no data for variable "C"?
You may see my steps above.
Posted: Mon May 27, 2013 8:25 pm
by startz
Just put C in with the list of common coefficients. You don't have to define it because "C" is predefined.
Posted: Mon May 27, 2013 8:30 pm
by devi.lupita
It works! thank you soooo much for your help.
Posted: Mon May 27, 2013 8:38 pm
by devi.lupita
One question more, I automatically got the constant term, F-statistic and probability when I estimated my data using another method without put "C" in with the list of common coefficients.
Could you please explain me about this?
Posted: Tue May 28, 2013 6:25 am
by startz
You would need to show exactly what you did.
Posted: Tue May 28, 2013 9:16 am
by devi.lupita
I estimated my data with those method (Fixed and Random Effect).
I didn't put "C" in the list of common coefficients, but I got the constant term, F-statistic and probability on my output automatically.
These are the step and output of fixed effect data estimation
These are the step and output of random effect data estimation
