Re: Freequency Conversion
Posted: Fri Dec 16, 2011 10:56 am
File received.
The problem is that your first page is not structured as a dated page. Further, you can't structure it as a dated page because you have duplicate date/time pairs.
I can't help further without knowing what your intentions are with regards to the conversion from irregular/duplicates to a regular time frame. Again, what are you going to do if an observation isn't on the 5 minute mark, and what are you going to do if there are more than one observations on a 5 minute mark?
-The thing is that I cannot structure the first page. My dataset is defined at miliseconds and the options to date the sample is up to seconds. What if I structure this as 'seconds'. Will the the millisecond-observations be lost? And even then will this work?
- I do not need to keep observations between the 5minute mark. I need the ones exactly at the 5-min mark in order to generate 5-min returns.
- In case there are more than one data at the 5-min mark, i can just keep the last one (I suppose E-Views handles it like interpolation), or even the everage of them.
Is there any possibility to convert them now?
Thanks again
Panos
