Ridge (Ridge Regression and Ridge Trace)
Re: Ridge (Ridge Regression and Ridge Trace)
Ridge Trace seems to work for me - I get a nice graph and table.
Could you please enlighten me? Have you used the excel file?Ridge Trace seems to work for me - I get a nice graph and table.
I inserted to the existing file the forecast lrconsf from the excel (f row) . (as you will see in the new workfile I attached)
When I run the ridge trace what do I put in dependant: the forecast? lrconsf? I tried everything and I am just getting a blank graph?
I am new to Eviews, sorry for the 'stupid' questions!
Thanx in advance!
- housingfor.WF1
- (11.97 KiB) Downloaded 14847 times
Re:
In the ridge regression i put: dependant lrcons and independant: lrgdp lrprice
As I said earlier the ridge regressions gives me the results, but the ridge trace add-in is giving me the blank graph
I made you a print screen and I think you will understand the problem.
- graph.jpg (60.01 KiB) Viewed 58531 times
- printscreen housing.jpg (126.2 KiB) Viewed 58531 times
You appear to be entering only a single biasing constant for the Trace. As the instructions indicate, you need to enter a list of values.
Thank you, that was clearly my bad!
But again one problem, hopefully the last!
Given the automated sort of values in the ridge trace (0 , 0.5..etc) I run it and I got the following error message!
- error.jpg (63.82 KiB) Viewed 58528 times
Hard to say without knowing what you did.
This is what I run! And I got the same error! I used an alternate sample and also got the same!
forgot the image sorry!This is what I run! And I got the same error! I used an alternate sample and also got the same!
- screen1.png (23.62 KiB) Viewed 58523 times
Works for me.
- ridgetrace.png (111.68 KiB) Viewed 58522 times
Unbelievable or what? We are doing the exact same thing and getting 2 different results. Perhaps I miss a plugin or something? I installed the plugin straight from the site, no problem in installation...
Do not know that to say...
Is your copy of EViews completely uptodate?
At last!! The update was the problem!! I see the beautiful graph too!!!Is your copy of EViews completely uptodate?
Thanx a lot!!
I would like to ask something more about the ridge regression. The baysan value has to be under 1??
Thank you in advance
Added to my previous question about the ridge regression , I would like to ask you what exactly does the VIF represent in the ridge traceHello,
Thanx again.
