Ridge (Ridge Regression and Ridge Trace)
Re: Ridge (Ridge Regression and Ridge Trace)
Postby EViews Gareth » Wed May 18, 2011 1:56 pm
Ridge Trace seems to work for me - I get a nice graph and table.
stasibab
Postby stasibab » Wed May 18, 2011 5:37 pm
Could you please enlighten me? Have you used the excel file?
I inserted to the existing file the forecast lrconsf from the excel (f row) . (as you will see in the new workfile I attached)
When I run the ridge trace what do I put in dependant: the forecast? lrconsf? I tried everything and I am just getting a blank graph?
I am new to Eviews, sorry for the 'stupid' questions!
Thanx in advance!
housingfor.WF1
(11.97 KiB) Downloaded 14847 times
Re:
Postby EViews Gareth » Wed May 18, 2011 6:10 pm
In the ridge regression i put: dependant lrcons and independant: lrgdp lrprice
stasibab
Postby stasibab » Wed May 18, 2011 6:33 pm
As I said earlier the ridge regressions gives me the results, but the ridge trace add-in is giving me the blank graph
I made you a print screen and I think you will understand the problem.
printscreen housing.jpg (126.2 KiB) Viewed 58522 times
Postby EViews Gareth » Wed May 18, 2011 7:19 pm
You appear to be entering only a single biasing constant for the Trace. As the instructions indicate, you need to enter a list of values.
stasibab
Postby stasibab » Wed May 18, 2011 7:29 pm
Thank you, that was clearly my bad!
But again one problem, hopefully the last!
Given the automated sort of values in the ridge trace (0 , 0.5..etc) I run it and I got the following error message!
Postby EViews Gareth » Thu May 19, 2011 9:01 am
Hard to say without knowing what you did.
stasibab
Postby stasibab » Thu May 19, 2011 9:36 am
This is what I run! And I got the same error! I used an alternate sample and also got the same!
stasibab
Postby stasibab » Thu May 19, 2011 9:38 am
forgot the image sorry!
Postby EViews Gareth » Thu May 19, 2011 9:43 am
Works for me.
stasibab
Postby stasibab » Thu May 19, 2011 9:56 am
Unbelievable or what? We are doing the exact same thing and getting 2 different results. Perhaps I miss a plugin or something? I installed the plugin straight from the site, no problem in installation...
Do not know that to say...
Postby startz » Thu May 19, 2011 11:04 am
Is your copy of EViews completely uptodate?
stasibab
Postby stasibab » Thu May 19, 2011 3:10 pm
At last!! The update was the problem!! I see the beautiful graph too!!!
Thanx a lot!!
stasibab
Postby stasibab » Wed Jun 08, 2011 3:13 pm
I would like to ask something more about the ridge regression. The baysan value has to be under 1??
Thank you in advance
stasibab
Postby stasibab » Wed Jun 08, 2011 3:25 pm
Added to my previous question about the ridge regression , I would like to ask you what exactly does the VIF represent in the ridge trace
Thanx again.
Return to “Add-in Support”
