Page 2 of 3
Re: Error "Variable is not defined" in panel ARDL
Posted: Wed Jan 06, 2021 7:44 am
Hi. Thanks for your feedback. You do not understand me because I can not save the work file and post here (this lite version do not allow me) so that it is easier for you to understand. I will stop asking this question. Thanks
We’re not asking for the workfile, we’re just asking you to tell exactly what you are doing. In words.
Posted: Tue Feb 22, 2022 6:06 pm
by academia1
Hi, I was regressing a set of data in my model in Eviews applying OLS.
My model is: GDP = β1 + β2 FDI + β3 ODA + u
Yet, when I input the above model in Eviews, there was an error message: "GDP is not defined."
Do you know how to fix the above error so that I can run my model in Eviews for results?
Thank you.
Posted: Tue Feb 22, 2022 6:10 pm
by startz
Is there a variable named GDP in your workfile? Can you show us exactly what command you entered?
Posted: Tue Feb 22, 2022 6:43 pm
by academia1
Yes, I input GDP as a variable in my work file.
The command I used was stated above.
Yet I encountered the above error.
Then I don't know how to fix it.
Please advise.
Posted: Tue Feb 22, 2022 6:46 pm
by startz
try
ls GDP C FDI ODA
Posted: Tue Feb 22, 2022 7:06 pm
by academia1
I input the above command.
There was an error message: "LS is not defined."
What should I do if Eviews keeps showing errors?
Thank you.
Posted: Tue Feb 22, 2022 7:14 pm
You should start by following instructions.
Please tell us exactly what you are doing.
Posted: Tue Feb 22, 2022 7:57 pm
by startz
In particular, where did you enter the command? Maybe even post a screen shot of your EViews window including the command and the workfile window.
Posted: Tue Feb 22, 2022 8:53 pm
by academia1
I input the above commands in Eviews.
Below are the screenshots.
It keeps showing the message that the variables are not defined.
How to fix these errors?
Posted: Tue Feb 22, 2022 9:00 pm
by startz
Two things:
I believe your data isn't organized correctly. In your Excel file you probably want one column for GDP, another for FDI, etc.
Then in the estimation window just type in the list of variables, no coefficients. Include C to get an intercept.
Consider taking a look at the free EViews Illustrated.
Posted: Wed Feb 23, 2022 12:36 am
by academia1
I tried to input another command with another excel file
Below are the screenshots of the command
Yet I saw the same error message that the variable is not defined
What does this error message mean?
I looked at some tutorials yet they did not mention this case.
I am using a Demo version of Eviews. Is it because it is a Demo version so the above error appeared?
Thanks.
Posted: Wed Feb 23, 2022 7:53 am
by startz
Your Excel spreadsheet should have one column for each variable. The first row should be the variable name and the entries below that should be the data. Look at Chapter 2 of EViews Illustrated. Or it might be just as easy to enter the data directly in EViews.
Please don't post photos of your screen. They are too hard to read. Post a screenshot taken on the computer.
Posted: Fri Feb 25, 2022 2:24 am
by academia1
I applied another Excel spreadsheet and input a new command on Eviews with only the variables and the constant.
Yet there was an error message:
"Alpha series in specification - GDP
@EXPAND can convert to catagorical dummies."
What does the above error mean and how to fix it?
Below are the screenshots. Thanks.
Posted: Fri Feb 25, 2022 7:24 am
The gdp data contains characters, not numbers
Posted: Fri Feb 25, 2022 6:50 pm
by academia1
Do you mean the data can contain only characters but not the figures?
Attached are the data that I applied in this Eviews command.
There appeared the error message like above. Pls advise. Thks.
