vector error correction model with panel data
sabujkumar
I want to perform Granger causality test in the error correction based framework. my data set is balanced panel of 18 states with 26 years. my dependent variable is output (y) and independent variables are capital, labor, material and energy. i want to test the direction of causation between output and energy (both short run and long run). how to do it in EVIEWS 6?
Re: vector error correction model with panel data
I was wondering if you found a solution to this question because I am currently facing the same exact problem now? Can you pls share the solution if you have found it? Thanks!
