Converting Standard Errors/Deviations
kkp318
Postby kkp318 » Fri Aug 13, 2010 11:27 am
I have a regression that I've calculated on a growth series, but I'm looking to now convert that series to levels and graph it. I want to create a band of standard errors or standard deviations for the level series, but I can't figure out how to convert the standard errors and standard deviations to correspond with the level series rather than the growth series. Does anyone know if Eviews 6 is capable of doing this? And if you can do it in Eviews, can you tell me how? Thanks for the help!
trubador
Did you use forum search?
Re: Converting Standard Errors/Deviations
Postby trubador » Fri Aug 13, 2010 12:22 pm
If you defined the dependent variable in terms of EViews' functions (e.g. dlog(), @pc()), then you would have both options (level and change) to generate in-sample forecasts along with error bands. Hit the "Forecast" tab in the Equation window to see your options.
