Aggregating Cross-Sections in Pools
pmgm
Postby pmgm » Mon Aug 09, 2010 2:06 pm
Dear all,
I would like to aggregate cross-sections (e.g. countries into regions) in a pooled workfile. So far I have got (e.g. for Asia):
for %v GDP POP INF NER EXP IMP FDI
series {%v}_Asia = 0
for %c BN FJ ID KH KP LA MM MN MY PG
{%v}_Asia = {%v}_Asia + {%v}_{%c}
Not the tidiest of codes, as I need to repeat this for all regions (about 20). Could anyone suggest a way to include the regions in the loop?
Many thanks.
Re: Aggregating Cross-Sections in Pools
Postby EViews Gareth » Mon Aug 09, 2010 2:20 pm
Like this ?:
for %r asia europe americas for %v GDP POP INF NER EXP IMP FDI series {%v}_{%r} = 0 for %c BN FJ ID KH KP LA MM MN MY PG {%v}_{%r} = {%v}_{%r} + {%v}_{%c} next next next
pmgm
Postby pmgm » Tue Aug 10, 2010 1:25 am
Thank you for your quick reply, Gareth. Unfortunately that would not work, since each region has different members. Say we have:
Asia = BN FJ ID KH KP LA MM MN MY PG
Americas = CR CU DO GT JM MX NI SR TT
Africa = AO BF CV TD KM ET GA GN GW KE
Europe = FR DE LU NL GR IS IT
etc…
The code suggested would create regional variables with the same values (_Asia = _Europe) since they would be based on the same group members (in this case, Asian countries), i.e. %c.
I have created pool objects (one for each region to identify their members), but I am not sure how to insert this information in the loop.
Thank you again.
Postby EViews Gareth » Tue Aug 10, 2010 8:05 am
There is probably a clever way using pools, but I'm not a pool fan and never use them as much as I should.
You could use string lists though. This code isn't tested, but the idea should work even if there is a mistake:
%Asia = "BN FJ ID KH KP LA MM MN MY PG" %Americas = "CR CU DO GT JM MX NI SR TT" %Africa = "AO BF CV TD KM ET GA GN GW KE" for %r asia americas africa for %v GDP POP INF NER EXP IMP FDI series {%v}_{%r} = 0 %reglist = %{%r} for !i = 1 to @wcount(%reglist) %c = @word(%reglist,!i) {%v}_{%r} = {%v}_{%r} + {%v}_{%c} next next next next next next
