Number Format Problem
oneoff
Postby oneoff » Sun Aug 08, 2010 9:16 am
hi everyone,
Using Eviews 6, I've encountered a problem when trying to import excel data. The order is actually as follows, I created a table in SPSS, copy/pasted it into a new workfile and then saved it as an excel file (there are reasons for it ;) Now I have the problem that eviews is not taking over the number format, e.g. my price-index 98,21 is made into 9821,00 and for some reason 101,91 is made into 10191,00 so it seems kind of random. I really cannot find a way to change this! The only thing I did discover is that one of my series, i.e. exchange rates has maintained the original format, but eviews labels this as an alpha series or something, so 'abc' instead of a normal series symbol.
How can I maintain/change number formats and change alpha series into normal ones?
Thanks alot in advance,
Mike
Postby EViews Gareth » Sun Aug 08, 2010 10:24 am
Can you post the Excel file?
oneoff
Re: Number Format Problem
Postby oneoff » Sun Aug 08, 2010 11:48 am
hi,
thanks for your reply, this is my data, must be some comma problems but I can't it. Thx
data.xls
(28 KiB) Downloaded 298 times
Postby EViews Gareth » Sun Aug 08, 2010 3:55 pm
I opened that file in EViews 6, and it appeared to open just fine.
Postby startz » Sun Aug 08, 2010 4:34 pm
Gareth,
Out of curiousity, I opened this in 7.1 and only the first three data columns came in.
Postby EViews Gareth » Sun Aug 08, 2010 5:55 pm
On the first step of the open, rather than using "Predefined range", use "Custom Range" and set the range to be D3:J124
oneoff
Postby oneoff » Tue Aug 10, 2010 1:55 am
hi again,
I'm puzzled. it just doesn't work. My steps: open new workfile-date regular data, Quick-empty group (edit series)- copy from excel sheet and paste into columns. My price index is transformed from e.g. 86,41 into 8641.000 and my exchange rate is converted into a date (i.e. from 1,07 into 1/7/1999 or something). It's really annoying being stuck at the initial step of inserting data. Does anyone have a proper solution? Thx
Mike
Postby EViews Gareth » Tue Aug 10, 2010 7:59 am
Open the Excel file. i.e. File->Open->Foreign Data as Workfile
