error distributin test
I have selected the "normal" option for the error distibution when estimate ARCH, however, I cannot find any results regarding to normal distribution from the equation window, how can I tell if the residuals from the my model is normally distributed or not please?
Re: error distributin test
Look at the Jarque-Bera statistic to the right of the histogram.I have selected the "normal" option for the error distibution when estimate ARCH, however, I cannot find any results regarding to normal distribution from the equation window, how can I tell if the residuals from the my model is normally distributed or not please?
but that's not from the ARCH test window itself, you have to conduct another test by using 'view' ... if I selected t-distribution, i will have a row of t-distribution statistic results shown, I find nothing when I use 'normal distribution' option...Look at the Jarque-Bera statistic to the right of the histogram.I have selected the "normal" option for the error distibution when estimate ARCH, however, I cannot find any results regarding to normal distribution from the equation window, how can I tell if the residuals from the my model is normally distributed or not please?
You are choosing the distributional assumption for the error. I believe the row you are seeing is the estimated degrees of freedom. It's not a test of the distributional assumption.but that's not from the ARCH test window itself, you have to conduct another test by using 'view' ... if I selected t-distribution, i will have a row of t-distribution statistic results shown, I find nothing when I use 'normal distribution' option...Look at the Jarque-Bera statistic to the right of the histogram.I have selected the "normal" option for the error distibution when estimate ARCH, however, I cannot find any results regarding to normal distribution from the equation window, how can I tell if the residuals from the my model is normally distributed or not please?
