Hi, I am handling data with some missing values. Now I want to import these data into eviews.
So here comes the problem.
If I appoint start date and end date, when I import data into eviews, the date and the data value will not match. Because I have about 5000 observisons, It was impossible to find out which one is wrong.
If I didn't appoint start and end date, just use integer day 1, 2, 3, ...., 5000, when I plot my series, the X-axis lable will be 1, 2, 3, ...., 5000 instead of actual day,such as Jan, 1, 1990.
How can I solve this problem?
Thank you!
How to handle missing value at some paticular day?
bit_xiaoxiao
Re: How to handle missing value at some paticular day?
You'll need to provide more information.
How does your data look prior to being imported into EViews?
Is there a column containing date information?
How are you doing the import?
bit_xiaoxiao
Thank you, I have already solve it. Just use "Structuring a Workfile".You'll need to provide more information.
