detecting multicollinearity
mscarlatos
Postby mscarlatos » Tue Jun 29, 2010 7:46 am
I am unable to pull up Eviews Help anymore for some reason. Could someone tell me whether or not Eviews can run a collinearity test between two or more variables?
Re: detecting multicollinearity
Postby EViews Gareth » Tue Jun 29, 2010 7:52 am
From an estimated equation there are a few diagnostics to help you determine collinearity between the regressors - Variance Inflation Factors, and Variance Decomposition.
mscarlatos
Postby mscarlatos » Tue Jun 29, 2010 10:22 am
Dear Mr Evans: Thank you but could you be a bit more forthcoming: I run a regression but where do I look for VIF and Variance Decomposition? I ask since I cannot find them under any of the Views or Procs. Thank you.
Postby EViews Gareth » Tue Jun 29, 2010 10:26 am
View->Coefficient Diagnostics.
mscarlatos
Postby mscarlatos » Tue Jun 29, 2010 12:06 pm
Under view, I see "coefficient tests" under which I do not see anythign measnuring multicollinearity unless "redundant variables" measures that. However, without even regressing, I find under "quick"..."group statistics"..."correlations." Does the latter serve as a measure of collinearity?
Postby startz » Tue Jun 29, 2010 12:33 pm
What version of EViews are you using?
mscarlatos
Postby mscarlatos » Tue Jun 29, 2010 12:34 pm
Eviews6
Postby startz » Tue Jun 29, 2010 12:48 pm
The multicollinearity diagnostics were introduced in EViews 7.
Just out of curiousity, why are you concerned about multicollinearity?
