I am new in programming in Eviews.
Is it possible to calculate unit roots of several variables in the same workfile with programming?
All parameters has different name (aust, germ, fra, fin, etc), but I will check unit root for all parameters.
I will use KPSS test (level, intercept section as chosen for test).
If it can open several windows for all parameters (like manual case) after test with a programming, I can get full result by checking all results windows. Is it possible?
Thanks in advance
Kelaynak
how to make programming for unit root loop calcution
