I'm estimating a model with cross-section SUR and would like to obtain an estimate of the correlations across cross-sections and ideally be able to assess their significance. How should I proceed? Or should I find this in the default output?
Thanks for any advice.
Contemporaneous correlation in cross-section SUR
Re: Contemporaneous correlation in cross-section SUR
If you are in a panel workfile, the best thing to do would be to compute a variant of the cross-section dependence test. There's a discussion of this at
http://forums.eviews.com/viewtopic.php? ... &sk=t&sd=a
