Non-linear Gmm - Near singular matrix problem
rhaos69
Postby rhaos69 » Sun May 30, 2010 4:53 am
Hi everyone!! It's the first time i write here because i have a very furstrating problem.....I want to replicate the results of a paper, where non linear gmm is used in panel data...
I want to estimate with quadratic Andreus spectral kernel the following equation : c(1)*con_g(1)^(-c(2))*inf(1)^(-1)*t_bill-1 with instruments : i con_g inf t_bill(-1).
I have created a new object system and write the following :
@inst i con_g inf t_bill(-1)
where con_g is consumption growth rate, inf is inflation rate and t_bill is interest rate and i a vector of ones......
When i press estimate, i always get an error message of near singular matrix...... I've tried several things and saw that, whenever the term inf^(-1) was removed and also i was putting a value at the c database an estimation was made........But the problem is that i cannot estimate my initial equation because of the error....
I was wondering what is the fault?? Have i done something in writing the system or is the data that create a problem??
Thank you for your patience....
panel for all.wf1
(108.98 KiB) Downloaded 264 times
Re: Non-linear Gmm - Near singular matrix problem
Postby EViews Gareth » Tue Jun 01, 2010 10:16 am
You can't use 0 as a starting value for c(1), since if c(1) is equal to zero, the value of c(2) is irrelevant (and thus you can get a singular matrix).
Try using 0.5 as a starting value for c(1).
rhaos69
Postby rhaos69 » Wed Jun 02, 2010 4:23 am
I seen that when i change the value of c(1) (and c(2) sometimes) i get results. I just don't know if this is good for the estimation, because the paper i replicate doesn't write something about initial values.........unless it is considered that it doesn't have to be mention....
Postby startz » Wed Jun 02, 2010 6:52 am
Indeed, papers generally do not mention initial values.
