Need help dummies and trends urgent
mandrake
Postby mandrake » Sat May 29, 2010 3:59 am
Hey
I have a panel data set. There are 15 cross sections, countries. There are 11 time periods, 1998 to 2009.
My first question is, i have a dependent variable gendergap, how can i make a trend on this so that i can include it in the regression ? I know how to detrend the variable, but i want to be able to use the trend variable in the regression. Anyone? I have panel data by the way. It is organised like this:
austria 98 obs
austria 99 obs
austria 00 obs
belgium 98 obs
belgium 99 obs
and so on for each of my variables. Every variable have their own series which is coded like mentioned above. How can I make dummy variables for each country and each year? I tried, and I thought that I was succsessful, but then I got uncertain. When i included the dummy variable for the years in addition to a dependent an independent and an intercept, the coefficient on the independent changed when i was either including the dummies or not. Arent the dummies supposed to only report extra information, and not change the coefficient on the independent variable?
Example regression: ls gendergap c gdp d99 d00 d01 d02 d03 d04 d05 d06 d07 d08 d09
and just this regression: ls gendergap c gdp
These two regressions give different coefficients on the gdp variable, is that right?
Also, having panel data, how can i include fixed effects in my regression`? Also, any opinions on how to check multicollinearity in a panel data set`?
Does my structure of panel data look ok to you? I realise that this is many questions, but please help me with as many as you can. It\s pretty urgent. I can also send my dataset to someone if needed. Any help is appreciated.
Edit: I added my eviews workfile also. Please help.
Sincerely,
Christian
Eviews workfile.WF1
(59.28 KiB) Downloaded 298 times
Postby startz » Sat May 29, 2010 4:18 am
Including dummy variables generally does change the other coefficients.
mandrake
Re: Need help dummies and trends urgent
Postby mandrake » Sat May 29, 2010 4:10 pm
Anyone?
