t-test on β3>β4 reparameterization
rojjo
Postby rojjo » Wed May 26, 2010 9:17 am
I'm running a multiple linear regression on the dependent variable KMLIT and independent variables CYL, ENGCM3, HP and WTKG
I need to do a t-test to see if one unit increase in HP has greater detrimental effect than one unit increase in WTKG.
With reparameterization:
Test β3>β4 = β3-β4=0
Let Φ=β3-β4
H0: Φ = 0 β3-β4=0 β3=β4
H1: Φ > 0 β3-β4>0 β3>β4
I ran the estimation: kmlit c cyl engcm3 hp (hp+wtkg)
However the result is that I can reject the null with the P-value but fail to reject using the t-stat.
All of the four independent variables have a negative coefficient, which I think is the problem. Will I need to change the signs somehow?
Dependent Variable: KMLIT
Method: Least Squares
Date: 05/27/10 Time: 02:05
Sample: 1 300
Included observations: 300
Coefficient Std. Error t-Statistic Prob.
C 14.13693 0.422440 33.46494 0.0000
CYL -0.058797 0.115682 -0.508266 0.6116
ENGCM3 -6.07E-05 0.000150 -0.404790 0.6859
HP -0.008236 0.003475 -2.369906 0.0184
WTKG -0.003715 0.000426 -8.718605 0.0000
R-squared 0.780580 Mean dependent var 7.377235
Adjusted R-squared 0.777605 S.D. dependent var 2.241106
S.E. of regression 1.056879 Akaike info criterion 2.965043
Sum squared resid 329.5129 Schwarz criterion 3.026773
Log likelihood -439.7565 Hannan-Quinn criter. 2.989748
F-statistic 262.3631 Durbin-Watson stat 1.015431
Prob(F-statistic) 0.000000
Im using version 6
Re: t-test on β3>β4 reparameterization
Postby EViews Gareth » Wed May 26, 2010 9:20 am
Why not simply run the unrestricted regression, then do a wald test?
Postby startz » Wed May 26, 2010 9:32 am
What Gareth says is true, but your method also works. There is no difference between the t-test results and the p-value, although remember that the p-value is given for a two-tailed test.
rojjo
Postby rojjo » Wed May 26, 2010 9:34 am
OK, so what would I put as the restriction in the Wald-test?
rojjo
Postby rojjo » Wed May 26, 2010 9:46 am
Oh I probably misinterpreted the p-value.
HP+WTKG -0.003715 0.000426 -8.718605 0.0000
For H0: Φ=0, H1: Φ>0
The p-value is 0.0000 from the standard normal table with -8.71
But for the right tail its 1-0.000= 1
So at 0.05 significance i have
1>0.05 Fail to Reject null
-8.71<1.645 fail Reject null
Correct?
Postby startz » Wed May 26, 2010 9:50 am
c(3)=c(4)
or whatever coefficient numbers are appropriate in the original parameterization.
rojjo
Postby rojjo » Wed May 26, 2010 10:01 am
Startz,
I know I'm being a pain in the ass now, but just to make sure: so it doesn't make any difference that the coefficient are negative, it will just be absolute value anyway?
Postby startz » Wed May 26, 2010 11:40 am
Actually, you've done a nice job of carefuly explaining your question. It's a good model for all of us.
The sign doesn't matter, except that the "t" can come out positive or negative and one rejects on a one-tailed test while the other doesn't.
rojjo
Postby rojjo » Wed May 26, 2010 6:27 pm
Wouldn't you say it is very important though, whether to reject or fail to reject null? Atleast for my purposes it is.
The alternative hypothesis states that b3>b4 or numerically -0.008236>-0.003715.
Postby startz » Wed May 26, 2010 11:23 pm
Well yes, so if the estimated value of b3-b4 is significantly greater than zero you reject.
benbasb
Postby benbasb » Mon Jun 14, 2010 12:28 pm
I also have a question regarding the wald test...
I'm running a regression with two dummies. One which is 1 when returns of the S&P 500 are positive (usa_p) and the other is pretty logical: 1 when returns of the S&P 500 are negative (usa_n). And then I want to find out whether a negative return of the S&P 500 has a bigger or smaller effect on other indices, for instance of the FTSE100.
My regression looks as follows: uk=c(1)+c(2)*usa*usa_p+c(3)*usa*usa_n
When i want to compare these two coefficients is it possible that i just do a Wald test c(2)=c(3) and after that i could tell whether the coefficients are significantly different or not?
Thanks in advance!
