wfcreate
bhaupt
wfcreate
Postby bhaupt » Tue May 25, 2010 2:17 pm
I am running eviews 7.1 and I am up to date with updates.
I have a header file in which I specify a path, the forecast version, and (ideally) the number of datalines being read in from an excel sheet.
If I explicitly specify 43787 unstructured lines as in: (Case 1: this works)
wfcreate(wf={%netpath}\test\raw_fcst_{%cur_ver}.wf1,page=Raw) u 43787
the workfile creates without a hitch; however, if I attempt to include the number of lines in my header file as
'# Current & Previous Forecasts %cur_ver="0510" !cur_vlen = 43787 'length of datafile
when I execute the wfcreate command I get an Illegal Date error: (Case 2: this fails)
wfcreate(wf={%netpath}\test\raw_fcst_{%cur_ver}.wf1,page=Raw) u !cur_vlen
My include statement is called beforehand. The program runs with no errors if I specifcy the 43787 as the number of observations.
I have tested at the command line and the illegal date error occurs again, however in the popup, it says !cur_vlen in the number of observations field, meaning it seems to take it as a string literal instead of as a numeric variable I was hoping it would think it should be.
Is it a Bug, a feature, or am I doing it wrong?
Re: wfcreate
Postby EViews Gareth » Tue May 25, 2010 2:21 pm
Not sure I exactly follow what you're asking. But I just did the following steps, and it worked fine. I think it is what you are trying to do.
I created a program file called "DEFAULTS.PRG". In that file there is a single line:
!n=100
I then create another program and in it are the lines:
include default.prg wfcreate u !n
And that worked perfectly.
Re: wfcreate
!n=100
bhaupt
Re: wfcreate
Postby bhaupt » Wed May 26, 2010 6:24 am
I'll try it again...
followup edit:
I changed my variable name to !n rewrote the line and, yes, it worked properly. I then reconstructed the line and it failed. I then rewrote the line and it worked. I don't have an explanation, but I do have a working program.
