SVAR batch automation, and impulse response tabulation
ckaas
Postby ckaas » Thu May 13, 2010 1:26 am
I am working with a cumbersome amount of data, and am trying to put together as many batch programs as possible to automate the generation of impulse responses (and, later on, variance decompositions). I have run into a bit of a snag, however, and hope that someone might be able to offer some insight into the problem.
I have multiple time series in a workbook, and would like to write a program that would:
(1) Run VARs on each of the series, and impose short-run restrictions
(2) Generate impulse responses for each VAR
(3) Save the results of the impulse responses into a single matrix/table
For (1), I have written the following, which generates a VAR object for each of the series:
group var_group *
for !i=1 to var_group.@count
%name = var_group.@seriesname(!i)
var {%name}_VAR.ls 1 2 {%name} series01 series02 series03 series04 @
Question 1: What is the best way to incorporate the following type of short-run restrictions in the code?
@e1 = C(1)*@u1
@e2 = C(2)*@e1 + C(3)*@u2
@e3 = C(4)*@e1 + C(5)*@e2 + C(6)*@u3
@e4 = C(5)*@e1 + C(6)*@e2 + C(7)*@e3+ C(8)*@u4
For (2) I have begun playing with creating a loop around the following code:
seriesXX.impulse(10, matbyr=seriesXX_impulse) seriesXX @ series02
This creates a table object for each series, containing the impulse response of a seriesXX to an innovation in series02. Great, that's what I want. However:
Question 2: When I open the table object, I get many more columns than I thought I would. One of these corresponds to the impulse response I get when calling up the impulse response graphically by doing point-and-click. What do the other columns correspond to?
Question 3: I am wondering where I should go from here if I want to take the period-by-period impulse response of each SVAR I specified earlier, and put all these numbers into a single table? I haven't been able to figure this out yet, and may yet just resign myself to doing it manually.
Sorry for the rather long question. I'm new to batch programming in E-views, so I apologize if this turns out to be much simpler than I thought.
Thanks very much!
Christian
Re: SVAR batch automation, and impulse response tabulation
Postby EViews Gareth » Thu May 13, 2010 8:14 am
1)
{%name}_VAR.append(svar) @e1 = C(1)*@u1 {%name}_VAR.append(svar) @e2 = C(2)*@e1 + C(3)*@u2
etc...
2)
Use smat= instead of matbyr=
3)I think you're getting confused between tables and matrices. Step 2 actually created a matrix, not a table. You can use the matplace function to put matrices into bigger matrices.
ckaas
Postby ckaas » Thu May 13, 2010 9:50 pm
Wonderful! Thanks a lot. I've managed to create individual matrices with the results of the impulse responses, and combine all these into one big matrix. I'm trying to do the same with the results of the variance decomposition, now. For decomp, however, smat seems to create multiple columns again. I've tried to add the "@ mb" operator to restrict the output only to the variance explained by the series mb, but I'm still getting more columns in the output that I bargained for. Is there a solution to be found here as well?
I've copied my code below. It's the same I used for impulse, just replacing impulse with decomp:
group SVAR_group *
SVAR_group.[some stuff here]
for !i=1 to SVAR_group.@count
%name = SVAR_group.@seriesname(!i)
{%name}_var.decomp(20, t, smat={%name}x) {%name} @ mb
close {%name}x
close {%name}_var
matrix(21,48) decomp_results
decomp_results(1,!i)={%name}
delete {%name}x
Thanks again for the kind help.
Christian
