Warning in State Space Estimation
George
Postby George » Thu May 13, 2010 1:58 am
Dear all,
One more question regarding the estimation of state space models in Eviews. What does the message "WARNING: Singular covariance - coefficients are not unique" imply exactly and what can and must be done in order to eliminate this problem?
Thanks a lot in advance for your feedback!
Regards,
George
Re: Warning in State Space Estimation
Postby EViews Gareth » Thu May 13, 2010 8:01 am
It means that due to the specification of your state space model, there is no unique solution, and EViews is reporting one of the possibilities.
George
Postby George » Thu May 13, 2010 9:22 am
Dear Gareth,
Thank you so much for yuor reply.
Does this mean that the resolution of this problem can be achieved only through a redefinition of the model only? Or can changes in the initial values (coefficient and/or state) be a key to the solution?
Best,
George
maragloria
Postby maragloria » Fri Jul 16, 2010 12:00 pm
I'am also encountering the same problem. I have the same question as your last post. What did you do to solve the problem (is it indeed a "problem"?).
Thanks for your time.
Postby EViews Glenn » Fri Jul 16, 2010 1:55 pm
Changes in starting values *can* solve the problem. In some cases, only a modification of the specification will suffice.
