wfopen: Is rformat broken (v. 6)?
ericfruits
Postby ericfruits » Thu May 06, 2010 10:16 am
I tried using a WFOPEN command similar to the command in the help file:
wfopen(type=raw,rectype=fixed) c:\data.txt rformat=(GDP 1-2 INV 3 CONS 6-9)
However I receive the following error message:
Syntax error: unexpected character '(' in rformat specification
Consequently, the rformat specification cannot work.
Thanks.
Re: wfopen: Is rformat broken (v. 6)?
Postby EViews Gareth » Thu May 06, 2010 10:50 am
Bug in the documentation. Replace the parenthesis with quotes:
wfopen(type=raw,rectype=fixed) c:\data.txt rformat="GDP 1-2 INV 3 CONS 6-9"
We'll update EViews 7 so that it accepts parenthesis as well.
ericfruits
Postby ericfruits » Thu May 06, 2010 12:57 pm
Thanks for the quick and useful response!
zezza
Postby zezza » Thu Jan 02, 2014 8:16 am
I noticed today that the bug in the documentation is still there... rformat will not accept brackets.
It works fine with the suggestion from Gareth
Postby EViews Glenn » Mon Jan 06, 2014 12:25 pm
Thanks. I put this on the list of things to take a look at. Sorry.
